It is currently Mon Sep 15, 2025 8:05 pm
PostPosted: Wed Aug 17, 2022 2:48 pm
Last Name: Ensor
City: Springfield
State: Missouri
How thick is your bridge when you slot it? (Example: finished thickness- around 3/8", raw stock- 1/2" +, etc)
Thanks.
http://elevatelutherie.com
http://ensorguitars.com
PostPosted: Wed Aug 17, 2022 3:09 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Raw stock ranging from about 3/8" to about 7/16" thick.
PostPosted: Wed Aug 17, 2022 4:08 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
I slot mine before I cut it out of the blank at just a bit more than finished thickness which is usually around 3/8”.
PostPosted: Wed Aug 17, 2022 5:22 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
+1
PostPosted: Wed Aug 17, 2022 5:43 pm
Last Name: Kincheloe
3/8 to 7/16. I drill the pin holes and route the slot, then taper the thickness from the back so the slot and holes are tilted back a few degrees, to counterbalance the forward rotation under string tension.
PostPosted: Wed Aug 17, 2022 6:21 pm
I route the slot after the bridge is on the guitar. Started doing that after I started doing repairs and got used to it. My bridges are usually about 3/8" like most.
PostPosted: Wed Aug 17, 2022 6:42 pm
3/8 + 1/32. The 1/32 gets sanded off when I match the bridge bottom to the top radius, for a 3/8” finished bridge…
PostPosted: Wed Aug 17, 2022 6:59 pm
Wiggle room is always nice but I generally aim for a slightly thicker than 3/8th inch block before routing out.
PostPosted: Wed Aug 17, 2022 8:01 pm
First name: Brad
Last Name: Combs
I think I’m the same as Ed. It’s all done on the CNC but the block is .400.
PostPosted: Wed Aug 17, 2022 8:14 pm
As Steve mentioned I rout the slot after the bridge is glued to the top. Bridge thickness 5/16ths to 7/16ths inch.
Users browsing this forum: Kbore and 72 guests
